Im facing severe problems with my PC for a whie now. First i felt my OS had gone bad and hence i reinstalled it. Then my pc wud fail after every 15 days and a fresh reinstall wud become necessary. This happened every 15-20 days and happened around 5 times after which my HDD failed. I realised my HDD wud have been the source of problem for everything which happened. I changed my HDD and reinstalled a new copy of windows (from a diff windows CD too this time).
Things were cool couple of times then n now again my pc begins to restart at will after 45-50 mins showing - Generic host process error for win32 services - due to some 'svchost.exe.mdmp' at a temp folder.
Also a BSOD screen appears if not the generic host process error for win 32 followed by a restart.
The BSOD used to appeared even b4 the HDD change and specified a
MACHINE_CHECK_EXCEPTION error at some mem location.
Pls check attached thumbnails for more info.
Could anyone pls tell me wat cud the problem be .. motherboard ram or OS or any solution/ suggestions ? Thanks in advance ppl.
