Help in building a Gaming Rig for 35k
hi guys... help me also... in deciding a good system for my own use...
config almost the same so i thought not to start new thread.
i would like to overclock to 3 - 3.5 GHz so that i can do it without adding cooler.
Processor --- Intel Pentium Dual Core E5200 - 3500
Motherboard --- Gigabyte GA-EG31M-S2 - 2550
Hard Disk - Western Digital 500GB , 16MB - 2875
DVD Writer - Samsung Sata 20x - 1200
Cabinet - Zebronics Bijli - 1000
Monitor - Samsung 2233sw - 10400 @deltapage.
RAM - 2GB -
Gfx -
SMPS -
please suggest good graphics card which can handle 22" monitor... while playing games (not a hard core gamer)and watching movies. also smps and ram.
i hope processor and motherboard is ok.
all these add up to 21525. have a total budget of 35k - 40k.
@ajith025
How about:
GPU: Palit GTX 260 894MB SP216 DDR3 ~16725
LINK: Palit Microsystems Ltd.
PSU: Tagan TG500-U37 500W SMPS ~3525
RAM: Transcend 2 x 2 GB 880Mhz DDR2 :~2200
TOTAL: ~Rs.22450
Guys, correct me if i am wrong.
thanks arpan for the reply...
is that the gpu required for 22" or is there any between 10 - 15k..?
transcend ram enough if i am overclocking... not much... upto 3 - 3.2GHz?
Go for Pi Black, makes no sense saving money there.
@ajith025
A 22" ideally has a resolution of 1680x1050, and trust me, GTX 260gtx 216 is more than enough for that resolution.
An alternative could be The 4870 512mb or 4870 1gb which again are awesome cards.[ Not sure of the price though( approx 14k for 4870 512mb and 16.5 k for 1gb)]. They wud cost even less via KMD.
Ram again it depends on you, if u really want to overclock it buy something like Corsair or G-skill, but ensure that u go for 4gb.Little more than your budget but Huge performance gain.
i hear some some issue at g31 board need bios update support e5200
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=2693#anchor_os
IntelPentium Dual-Core E5200 2.50GHz 2MB Wolfdale 45nm M0 65W 800 F8
cause i heard the board come with stock bios f1 or f4 or maybe f6
u need to update bios latest version support e5200 F8 will work the board not old bios setting
cause lastest version f9 for g31 board but stock setting new board will come stock f4 or f5 bios
btw why can u get assembled 10 system with 9x e5200 and 1 x7400 for server system maybe
and update the bios using @bios sofware latest version f9
and it will impove bug fix cpu support and some energy saving fix too
cause i am having wired problem at my ep45-dsc3 at stock bios f6
when i tried u power on it does not boot and i try man ram different slot and gpu card too even remove cmos clear cable but it fail
so i remove the board outside and test it work but the gpu card and ram read horrible memory i got first bios at horrible screen and i reset the ram 3 time it work fine after i final update bios to latest version f9 it improve and ran stable also oc work fine
Reactions: 1 person
@Arun.P
Thanks for the info.
I am anyway going to build one system first and then the other nine if i am satisfied with the performance.
I'll post the results in this section when the 1st system is ready.
