Help me build a VFM, space saving PC
Mohit said:
I was looking at something similar too but I need a powerful one which will at least me play some games too. The Apple I-Mac is way too expensive and Dell had something similar but not very powerful.
If anybody has any good suggestions, please share. Thanks.
This might interest you: AnandTech - Small Form Factor Buyers
If you want something even smaller and cheaper you can opt for a smaller case with i3 2100 and HD 6670 low profile.
m-jeri said:
None of these are possible. :(
I don't see how getting a PC with monitor would help then. :S Wouldn't it be a bigger problem since you would be confined to sit in one position?
Where do you use your lappy currently?
Thanks for the link. But which of those cabinets will I get it India and what are the other cabinet options that I have here? The i5 looks fine. Infact even the AMD rig mentioned in the article looks fine. I was thinking of the AMD rig with a better GPU maybe. CPU will be easy to decide. Main thing will be the GPU and the cabinet. Also a good power supply which will fit in the rig and work well.
