Monitors Help Me Choose A 19" Lcd !!!
I got the vx1932wm from Guwahati yesterday for 13950. So I believe it should be around the 11K mark in Delhi
i enquired abt the VX1932 yesterday only... its available for 11,800 in Delhi @SMC...
Btw.. Acer 22" AL2216W is available for 15,500
Model No. AL2216W
Product Name AL2216W
Display Size 22" Wide
473x296 mm
Pixel Pitch 0.282mm
Max Resolution 1680x1050
Max Reflash rate (Hz) 60Hz
Glare(Y/N) N
Response Time 5ms
Contrast Ratio 700:1
Brightness 300 cd/m2
Viewing Angle 170°(H),160°(V)
Colors 16.2M
Bit 6
Color Situation NTSC%
Pixel Error Standard B/D : 3D/D : 4Total : 5
Input Signal Analog or Dual Input(DVI w/HDCP)
VESA Wall Mounting 100x100mm
Speaker NA
Power Supply (100V-240V) Internal
Power Comsumption(OFF) <1W
Power Comsumption(Stand By) <2W
Power Consumption(ON) 55W
ALSO....is there ny real dif btw vg 1930wm and vx1932...i heard contrast ratios r same (vx having DCR but actual r same)...and same is G2G response time..wt say guys?
