[OT] with due apologies to Futureized
MIMO has a number of transmission modes:-
1. Transmit diversity is as you describe - bouncing multiple copies of the same signal around. You might be mixing transmit diversity for beamforming.
2. Beamforming adds phase to the signals making it narrow and amplified, and proper beamforming (like Ruckus does) uses antenna arrays.
3. Then there's spatial stream multiplexing. All n devices get their rated speeds from the number of streams being handled simultaneously - 1 antenna:1 stream = 150Mbps, 2A:2S = 300Mbps, 3A:3S = 450Mbps, etc.
I have no idea when exactly (or if at all) these devices switch over from stream multiplexing to sending out a single stream with diversity or beamforming. AC devices in contrast can match N bandwidth with a single stream giving manufacturers the flexibility to use other antennas for beamforming instead.
For example:- the N66U uses the Broadcom BCM4331. It clearly doesn't specify beamforming, and lists "space-time block coding" which is used in transmit diversity. While the AC66U using the Broadcom BCM4360, does list beamforming. I'm not saying n devices/chipsets don't support beamforming, there are a couple of Ralink chipsets (RT3593) which do. Beamforming was an optional feature on .11n and was mostly not implemented, which the .11ac standard seems to rectify.
[/OT]
MIMO is not necessarily beamforming, just as 4 tyres on a car doesn't necessarily make it 4WD.Beamforming is MIMO. You already have it in existing n-stream devices. MIMO improves reception by making better use of reflected signals. It does not actually increase range but rather decreases signal loss. The unintuitive bit with MIMO is you must have 'some' obstacles in the way so as to increase reflections to get better speed than a clear line of sight (!) MIMO is useless in an open field or less useful in a very large room.
Forget 5GHz, even 2.4GHz devices seem to be dropping power compared to devices from before. Probably stricter FCC regulations on transmit power?I've often wondered why this isn't the case presently with existing N 5 Ghz routers. Why can't they compensate somehow so that range on both bands is similar.
[/OT]
