CA50
Forerunner
This is my current setup. i have 1 x 120mm intake fans for the HDD at the front, and 2x80mm exhaust fans at the rear of the cabby. I am think of modding my case so m think to replace the two 80mm fan with a CM 120mm LED fan, and also wants to add another intake fan at the botton om my cabby (another CM LED fan)
This are my current temps, will the new fans able to lower the temps of my cabby
Current condition:
Thinking of...
My current temps
Current condition:
Thinking of...
My current temps
Sensor Properties:
Sensor Type Abit MicroGuru 2005 (ISA E0h)
GPU Sensor Type Analog Devices ADT7473 (NV-I2C 2Eh)
Motherboard Name Abit IP35 Pro / IX38 GT3 / IX38-MAX / IX38 QuadGT / IX48 GT3 / IX48-MAX
Temperatures:
Motherboard 42 °C (108 °F)
CPU 43 °C (109 °F)
CPU #1 / Core #1 35 °C (95 °F)
CPU #1 / Core #2 36 °C (97 °F)
PWM1 45 °C (113 °F)
GPU 54 °C (129 °F)
GPU Memory 46 °C (115 °F)
GPU Ambient 40 °C (104 °F)
Maxtor 6V080E0 48 °C (118 °F)
WDC WD5000AAKS-22V1A0 46 °C (115 °F)
Cooling Fans:
CPU 2040 RPM
System 2280 RPM
Aux1 2460 RPM
GPU 2419 RPM (60%)
Temperatures:
CPU 43 °C (109 °F)
PWM1 45 °C (113 °F)
GPU 54 °C (129 °F)
Cooling Fans:
CPU 2040 RPM
System 2280 RPM
Aux1 2460 RPM
GPU 2419 RPM (60%)
