rsaeon
Innovator
Whats up with ryzen setup having these very issues so common out of nowhere I might have to reconsider and go the stable intel way it seems whenever I might upgrade..
Mostly cpu memory controller compatibility issues with some RAM models... should be more stable with newer generations of ryzen cpus
The platform is still not yet mature. I have USB3 issues with my (linux based) 5900x + B550 system, forcing me to delegate those tasks to an Intel X299 system (also linux). Both systems are stress test stable with XMP, 3600MHz for AMD and 3200MHz for the Intel one. This is reflected on uptime as well. The Intel system is currently at 49 days with more than 50% load the entire time, while the AMD system is at 25 days at less than 20% load which is the last time the system halted due to USB3 issues before I moved that workflow over to the Intel system. The AMD system can crunch through in four hours what takes the Intel system twelve hours, despite having less cores. AMD processors are excellent with top notch performance, but the platform as a whole just isn't mature.
2) You mention that I'll need to do it on a non-Windows OS. Will I have to get a new OS (like Linux) installed and then run memtest through that, or are there options for that in the application already?
It's a bootable disk image that you can image onto a USB drive with a utility like Rufus: https://rufus.ie/en/
