J jith77 Inactive Explorer Apr 18, 2009 #21 phuchungbhutia said: Check the bios settings . . Enable the usb from there . . I had the same problem with hcl pc somedays ago . . Click to expand... usb controllers enabled in bios Euro_Rules said: Update your BIOS~!!!!!!!! Click to expand... already the bios is the latest
E Eazy Inactive Galvanizer Apr 18, 2009 #23 jith77 said: installed the latest available INF chipset at gigabyte site...didnt help Click to expand... Why dont you attach a screen capture of device manager showing USB status. Here is a screenie of my device manager which has USB setup properly on my Gigabyte UD3R Mobo.....
J jith77 Inactive Explorer Apr 22, 2009 #24 thanks all...its working fine now...just reformateed windows:hap2:
