Android How accurate is AccuBattery and do I need to get the battery replaced? (Samsung S10+)
It used to be AliExpress in the past but in recent years been getting it locally from the website below.
Can't find S10+ parts.
Any other alternative?
I also need Moto G5+ charging port replacement. Would be great if anyone can source any.
Finally replaced the charging port on the phone and the charging speed is back to normal, earlier it would be 7hrs or even 11:59 hrs to battery full. Now it's about 1:30-1:50 hrs to full.
However the severe battery drain is still present. I just realised that the battery drain might be due to software issues. I remember noticing the rapid drain since a software update last year. Even if the phone capacity is 2700mah I don't think it should be this bad.
About to update the software again. Keeping fingers crossed.
Last softwere update was on March 28, 2023.
I don't like software updates but did it as it supposedly has security fixes.
battary not able to keep up with software... u can try disabling animations and unwanted notifications.. location bluetooth...
best is still to replace battery...
After reading a number of posts on the issue I've come to the conclusion that battery drain is intended by Samsung to make the users upgrade their phones. Too bad my next phone won't be from Samsung.
