You can do that by installing ntfs-config , but you have the power of yast so there must be a drive manager and mount option..
If you want the hard way is like this
Mounting hard drive permanently is like this..
Open Terminal and type
Note only root can do that.
You will get something like this
Code:
/dev/sda1: UUID="725CA9255CA8E557" TYPE="ntfs"
/dev/sda2: UUID="a12c7c6c-3fd9-40ce-a4c9-16d1a3e8718e" TYPE="ext4"
/dev/sda3: UUID="dc6c0eaa-9e46-49c9-9df8-18fb4ec6c64f" TYPE="ext4"
/dev/sda5: UUID="c8a4b656-7c7d-4201-905c-9cd33df440b1" TYPE="ext4" LABEL="/home"
/dev/sda6: UUID="8720385a-12a3-439f-af44-a4c5be6d14bc" TYPE="xfs"
/dev/sda7: UUID="e5145b84-c13c-4937-9da8-c9b54be2cce1" TYPE="xfs"
/dev/sda8: UUID="3caa2240-d193-410c-971b-928fc639e26c" TYPE="xfs"
/dev/sda9: TYPE="swap" UUID="23136821-16e7-47cf-935d-b42fe46d91e3"
The only thing imp. is /dev/sda X or hda X incase of sata and ide respectively. and UUID for locating the partition..
Open /etc/fstab
Code:
gedit /etc/fstab
KDE : kwrite /etc/fstab
arrange your entry like this
Code:
For NTFS arrange in this fashion
[code]
# Entry for /dev/sda1 :
UUID=725CA9255CA8E557 /media/hd4 ntfs-3g defaults,umask=000 0 0
/media/hd1 can be /media/Docs or whatever you like. Note the new linux depends on /media for partitions mounting instead of /mnt that was used earlier..All the KDE and Gnome fetches mount point from /media/ now so mount it at /media
General way of arranging
UUID=<code generated from blkid> <mount point> ntfs-3g defaults,umask=000 0
Make sure you have ntfs-3g installed , opensuse now comes with new license thus no proprietary code in the DVD>
Now make the directories for the partitions
Code:
sudo su root or su-
mkdir /media/hd6
replace hd6 with what you have done in fstab
This will mount the partitions
Hope this helps
