IKEA Products you own and your use case
@raksrules how did u attach the stotta light to the boot . Have one but your use case works for me too
Some pics
^The light output of this light is equivalent to a phone led at 30 Lumens. That is quite dim so close range apps only where details aren't important just outlines. The plus side is battery will last longer between charges if run time is kept low.
Very useful to stand up on or sit down on.
Reactions: mh09ad5578
I have a couple of these Molgan lights , quite useful but the batteries die very fast , wish they were designed for AA batteries rather than AAA. Another thing to note is that the website mentions the turn off time as 10 seconds but in my case both my units turned off at different durations and at > 10 secs so not very reliable
I own a Linnmon/Adils table, which I have been using for a few years now. Still is a great table, but it has bowed in the middle a few cms, which is very noticable. Still supports all of the weight though.
Had these for a while before returning them.
Got a couple of the following, which work better.
Mi Motion Activated Night Light 2
Yeelight sensor nightlight (Sourced via sharesave service from Xiaomi before it was banned)
This is much better with a brighter light output option if needed.
It's magnetic also so you can attach it wherever and use it as a work light.
Reactions: sriharsha_m
This store happens to be stones throw away from my place and the owner himself is a proper DIY guy.
Reactions: blr_p
15L stock pot. It is silly that you can find made in India stock pots on Amazon.com and here I am buying a chinese made one from Ikea.
Reactions: ibose
I bought a couple non stick pans from ikea last year , although they are better than crappy brands in the market but they too failed in about 1- 1.5 year so wouldn't particularly recommend them
Reactions: raksrules
They make a decent plastic chair which can be disassembled. Used to be 600 when I bought it and was cheaper than most plastic chairs I could find then.
Not sure if anyone was ever looking for this but I was definitely looking for it.
I own a Kallax unit and I want to sub-divide a single cube into 2 slots (basically a shelf within a cube). Here is what I got from Ikea India couple of weeks back and as expected, it works like I want it.
This was not available in India before and I guess only was sold in Ikea UK website and such. Not even in US. But surprisingly saw it on Ikea India and immediately ordered one to test. Now might order more as per need.
Unfortunately the color (white) for me does not match my kallax unit (which is brown) but only white color is available so have to do with it.
I use plenty of these ikea batteries and their charger too , believe me when I say they are truly reliable and great and work for a long time
I am planning to get some stuff from Ikea online and was thinking to add the LADDA AAA Batteries too. Should I get their charger too? I ask this specifically as I have panasonic charger (which came with 4 eneloop batteries) that I bought back in 2016 and it does work fine but many a times, for batteries, it will give me blinking light which I guess indicates that as per the charger, battery is bad.
This basically means I cannot charge the battery at all.
Reactions: prime
I can vouch for the ikea charger. Even though simple to look at it has complex charging mechanism and can revive almost dead batteries. It worked for me on my old Duracell rechargeables.
Do you have the 4 battery charger or the one that can charge like 8-10 batteries and has some sort of battery storage inbuilt too?
I have both older model TJUGO (8 battery charger) and the new LITOSFÄR and both of them work flawlessly.
The new one can store almost 20 batteries in one go. So try the new model.
Reactions: YeAhx and raksrules
Please share the pics when you get KALLAX Insert. I also have a 4x2 KALLAX unit and had bought Polypropylene Storage Cubes when ikea was not delivering to NCR.
