Indian Sites for Electronics DIY Tinkerers/Makers to Shop for Tools and Components
I recently purchased some components from schofic.com and their service has been good. They have an amazon store and a brick and mortar store also(I think) and ordering from amazon storefront is costlier then from their own website. They shipped the order promptly but they seem to use amazon shipping who made sure the box is as much damaged as possible but fortunately the items where not damaged.
Website: www.schofic.com
P.S: Their first time user code didn't work for me saying user limit reached even though this was my first purchase, so maybe it is just for show
Anyone ordered from 3dprintronics? prices are pretty good there for diy 3d printer parts. Please let me if they are genuine
Anyone ordered from 3dprintronics, prices are pretty good there for diy 3d printing parts
They seem legit, check their youtube channel, a shady business won't go this deep to be shady.
Reactions: chungus
Thanks man. this is the best thread on this site
Reactions: Heisen
I bought a bunch of stuff from them over the years. I feel the prices are prices are higher than other places because they exclude GST.
Quality is usually pretty good. One time the custom cut profiles were done pretty bad, but that was just once.
I bought a bunch of stuff from them. I felt the prices are prices are higher than other places because they exclude GST.
Can you tell me sites which have better prices, I'm looking for corner plates with t nut for 40x40 extrusion
For 4040 extrusion, novo3d.in has the best prices. But their 4040 is dual slot, not single, but this means you can user cheaper 2020 hardware and brackets. Also their 4040 measures a little short, at 39mm.
Other places you could try is mechblock and robokits, I've had good experiences with both.
For some offset plates, I designed my own and had it laser cut out of aluminum or steel by robu.in
Everything here was purchased from novo3d, except the 2060, that's from 3dprintronics: https://techenclave.com/threads/diy...nn-elcom-rails-and-aluminum-extrusion.217143/
I built a lot of stuff with extrusions, this is my desk setup with 2060s:
and other random stuff:
  • Love
Reactions: skt907 and chungus
Wanted to order a smd chip and found it in a site called inkocean.in, It looks legit but I'm still not sure. sorry for bugging again and chip in question is ME 4057aspg it regulates lithium battery
I've ordered some transistors from them and received it. They seem to be an importer so you'll need to wait for a while for despatch as the stuff has to come in from probably China
Reactions: rsaeon and chungus
Ordered a few items from Makerbazzar and the support and delivery was very timely.
They even arranged for me oos stock stuff just under 72hrs.
Reactions: rsaeon
This part is available at lcsc - https://www.lcsc.com/search?q=me4057&s_z=n_me4057
However this is a clone of a very popular charging ICs from many other vendors, I suggest you find the exact model number of the IC you need, then look for the parameters in the datasheet for the particular IC, which look something like this, also look at the maximum VCC, charging current etc.
Based on this data you can use the IC from other vendors with matching parameters, the chip is so popular that pinouts on all the vendors match.
The popular TP4056 charging IC also has the same pinout. But do check the parameters, it's highly likely you will be able to use an alternative.
  • Wow
Reactions: chungus
