Intel AX201
15x cards availableWi-Fi 6 , Bluetooth 5.2
****Please note that AX201 is a CRF module (M.2: CNVio2) that uses the Intel proprietary interface, and thus can only be used with select Intel chipsets and platforms.
(CNVio2 cards only compatible with Intel 10th, 11th, 12th, 13th and 14th gen motherboards with M.2 E-key slot having CNVi support.)****
Also compatible with 10th gen & above tiny PCs
Intel® Wi-Fi 6 AX201 (Gig+) Product Specifications
Intel® Wi-Fi 6 AX201 (Gig+) quick reference guide including specifications, features, pricing, compatibility, design documentation, ordering codes, spec codes and more.
ark.intel.com
Rs 999 shipped per card
AX201 with Desktop Antenna Kit
(1 Kit = 1x AX201 card + 2x Dual band antenna + 2x Pigtail Connector + Case bracket + 1x M.2 screw + 1x bracket screw)
Rs 1249 shipped per kit
Currently 4x Antenna kits available at the moment can arrange more if required.
*** One week testing warranty from the date of delivery.
*** Buyer is requested to make a proper unpacking video without any cuts showing the shipping label and product clearly.
*** Buyer have to bear one side shipping cost in case of replacement and if the card is DOA (dead on arrival) I will bear shipping cost of both sides.
*** Discount for bulk buyer
*** Please check the compatibility with your system and do a proper research before buying, if unsure about compatibility PM exact motherboard or system model number.
*** If you have any question or query please feel free to contact via PM I will be happy to help.
