Hi
So im in a similar situation here.
I have a microteck 850 pure sinewave with invatubler it500 150ah batt ( both aged at 10y+) inverter has been repaired twice.
My recent reading show a 3+ kwh consumption at idle (no load) no less than 75watts always ( amciscience meter)
battcharging was not staying off for long, battery was quite warm, i had refilled the water about 30-45 days ago, had to redo it with apx 4l+ water last week.
Ovious conclusion was batt has gone bad, still i wanted more data, i gave it to a repair shop to test,
the load was lesser there, around 50-55watts when idle.
brought home a squarewave spare, this idles at 20-25 when done charging, not charhing too long as well. batt is not that warm as well.
So overall , im not sure where to go from here.
I have planned a bulb load test, to check the batt capacity .
technofast what did you finally do ?
