Linksys 5 port switch power compatibility
ubergeek
Forerunner
Hey guys i want to know whether a 12V dc and 2Ampere adpoter will work well with 5port 10/100 Work group switch?
the adopter which iam going to use works with llinksys wifi router so can the same be used?
the original adopter which came with it got fried so thats why
^ Just make sure the voltage rating is the same as the original adapter, amperage can be higher, it will draw only what it requires.
nope its 5V higher
