8TB might not be available in other than red or purple, but does not mean it will not be a binned drive - it could be a 8TB RED which was found defective and recertified at factory?. that is my issue.
Is it possible that refurb hard drives are repurposed for external storage?8TB might not be available in other than red or purple, but does not mean it will not be a binned drive - it could be a 8TB RED which was found defective and recertified at factory?. that is my issue.
Lower binned drives might be used for that but refurbed components for brand new external drives seems a bit icky from a company perspective in case somebody finds out.It is easy enough to find out HDD age with Crystal Disk Info and the likes don't you think?
I get your point though.This is more akin to taking a leap of faith keeping in mind that backing up a large capacity HDD to prevent data loss due to drive failure is a PITA.
However an 11-12k price difference is too tasty to pass up on.
@vivek.krishnan thanks for playing devil's advocate though.
Damn I am confused....![]()
Decided to go with your advice and curb the Desi Chindichor inside.I was going to pickup 2 of the 8TBs to put in a synology box, but passed it up when I saw that they had changed the HDDs twice or thrice - helium enterprise > WD Red > WD blue (maybe)
I would not want to take a risk in that case, as even though the device will be backing up to a cloud vendor, its something I dont like. I need to get rid of my 4*3TB HDDs
@cyberwarfare Your points?
Got a quote of 29.5k all inclusive from Velocity Computers for WD Red 8 TB .Will be putting down 10k as advance today.
They are saying they can get that within a week or so.
I am future proofing just to be safe.That as well as the point that I have 4 SATA ports is dictating my decision in this matter.Chucked the plan for a el cheapo 120 GB SSD for the OS drive and added the balance to get an 8 TB right now.Why are you going with 8TB? Do you need that much?
I have upgraded my main gaming rig only twice over the last 5 years but this little one has seen 4 upgrades from Core 2 Duo>Atom D410>AMD C350>J1800>J4205.Thats a standard cabby - you just need to add fans/ventilation holes in the front to get it cool.
I got this : https://www.techenclave.com/community/threads/itx-cabinet-morex-6600-w-o-psu.176032/
Found one of these....a very nifty back panel PCI slot SSD mounting kit.
http://www.amazon.in/CNCT-SSD-HDD-M...rue&ref_=ox_sc_act_title_2&smid=AU948FFA25IG5
C
The weirdest thing is that I have more or less lost my passion for gaming and now I am thinking since I have so much capital invested in terms of data and hard drives in this ITX rig it is the better bet to upgrade to a better PSU/cabby.
When it comes to cabinets I prefer the tall slim ones over the short fat ones...
I am willing to make an exception for a Fractal Node 304 though.It has enough space for 6 hard drives...
Just the fact that it is way overpriced in India for a 90$ case.![]()
I have a PCIe x1 slot only on this mobo as Apollo Lake has only 6 PCI lanes.Optionally, you could pay 2K, get a PCIe mount for a m2 SSD - either PCI or SATA key. But I would keep that slot free for a HBA like the M1015 which will allow more HDDs to be added.
If you have a cabby with 3 5.25" slots, you can do what I have done, get a 3x5 case which allows for 5 HDDs to be slotted vertically. Plus it come with its own fan.
Et tu Brute????
BTW I got my WD Red 8 TB (WD80EFZX) this weekend and set it up.Now I am in a quandary as to whether set up a spanned drive using my 4 and 8 TB Reds in tandem or not?
My only worry is that if one drive fails both will be screwed.
https://www.windowscentral.com/how-use-storage-spaces-windows-10
