41-50k Mini Itx Build for 50k using Ryzen Cpu
magesh85
Level F
Hi Guys,
I am trying to build a Mini-Itx Build as he wants a compact system.
He is looking for general use and media consumption and occasional gaming (gpu can be upgraded down the path too).
We are looking for Ryzen based system if possible under 50k.
Can you guys helps us out here.
Cheers!!!
You can always look at a:
Deskmini A300..(14K)
Ryzen 5 3400G (13K)
WD Blue SN 550 1Tb nvme SSD (10k)
16 Gb DDR4 RAM ( 6K)
Total : 43K
Add another HDD, SSD for storage as needed ( can get a 512 nvme in that case)
The Deskmini is not just a case.. It also has the Mobo, and Power Supply included.
Please note, I dont think you can add a discrete GFX card in this.
For doing that, you can go the separates way:
Fractal Node 202 ( case) - 6K
ITX PSU - 6-7K
Ryzen 3 3100 : 9K
ITX Mobo : 12K, https://mdcomputers.in/msi-b450i-gaming-plus-max-wifi.html
ITX GFx Card : 12K, https://www.pcstudio.in/product/gigabyte-gtx-1650-mini-itx-oc-4gb/
Total : ~60K
ITX PSU - 6-7K
Ryzen 3 3100 : 9K
Total : ~60K
I am unable to find the deskmini. Can you provide a link where I can purchase it?
I have a new nzxt h210i up for sale for 8k if you're interested. Also have a corsair sf600 if you want that but h210i also supports ATX PSU. I don't think 50k budget will allow for sf600 though
