Monitors Monitor Arm/stand for LG C3 48inch OLED (wall arm)
Party Monger
Juggernaut
Hi guys, I just got an LG C3 oled 48 inch Tv as monitor.
Im looking for a Monitor Arm for the said TV. On the left I have a window. The window ends at desk glass level. Need to mount it in the space below the window. It should go up and then have multiple arms to swiwel. When not in use it will be flat parallel to the window. When in use I should be able to pull it out and tilt left so it faces me. Also should have some wiggle room to push back or pull front/left/right.
I called up JIN office guys and they didnt have any wall arm that can support 48 inch. Weight of the TV is 15kg.
TLDR Need arm that mounts below window. able to push it back or bring it forward and turn left. And back against the window when I have company opposite the desk that I need to talk to.
