raksrules
Elite
ps: sorry for creating a new thread
Two days back i had got the MT882 modem at my home. I had applied for 999 UL plan. No technician came to my house. I did all the connections but the ADSL light kept on blinking and it was not showing any connection. when i connected the LAN cable the LAN light did not come
i restarted the laptop and LAN light came but after logging onto windows it went off again and it was not showing any connectivity. So connected using USB cable and it showed limited connectivity. But i just opened google and it opened.
first thing i did was do a speedtest and found the following :huh:
Now my question are
1. why is the LAN not working ???
2. i have 6 parallel lines in my home and just tried this by connection to one of them after removing phones from other lines. i think parallel lines will cause problem.
3. Most imp...how do i see what plan i am in and where to see it. i have not been provided with any user id or password:huh:
Now my question are
