mtnl triband users...need urgent help...plzzzz
set the router to bridge mode. google on how to do it.
easiest way to get things done. no port forwarding no jhanjhat
^^i tried that but my net connection got disconnected and i had to off and on the modem and change mode to pppoe to start internet again
rak007 said:
My modem is MT882 and i wanted to do port forwarding on the same for utorrent. I checked the below link
Port Forwarding for the Huawei SmartAX MT882
but the UI shown here is different from the one i find when i go to 192.168.1.1
I am not able to find virtual server anywhere. Can anyone please let me know how to go about ??
Use bridge mode :cool2:
Ensure you save settings. And make sure you create a dialer.
^^create dialer ???
how to do that and what does that dialer do ??
I mean currently i just plug in the modem to USB port and use net
I had the same modem before , i think somewhere in tools there is a save all or save to gateway option , click on it and your settings will be saved , then click restart router above it and it should have upnp enabled every time
rak007 said:
^^create dialer ???
you got the modem from MTNL right?
call up 1504.
tell them you want to set up your modem in Bridge mode with a dialer.
They will guide you on exactly what needs to be done.
^^ ok thanks...will call them next weekend (when i go home) and ask for technical help.
I hope they are technically sound enuf to answer such queries. Also after setting the modem in bridge mode would i get good speeds using torrents ?
I told you in the other thread that you are ALREADY getting the fastest possible speeds. I cant understand why you keep asking the same question again and again.
technically sound or not, all the MTNL staff need to do is follow a manual and give you instructions. that is something they do pretty well.
