Just interested to know on your choice of the BenQ PD3200U. This seems to be a monitor for use cases where color quality is important, e.g. digital art, videos etc. I'm sure that you have done research and selected the BENQ. But, I'm not sure if there is any benefit for programming which is your primary focus for the new rig. Sure, the syntax highlighting and fonts in terminals might pop a little more, but is it worth the almost 25-30k premium over say an LG 32UD59 or Samsung LU32J590UQW, both 4k 32 inch monitors.
I picked the BenQ primarily for the IPS panel and the feedback on the excellent viewing angles. I was primarily looking at the LG you mentioned, but saw discussion about how the contrast shifted depending on the viewing angle - especially considering there is so much screen real estate to influence angles. From what I understand, these are VA panels, albeit very good ones. For programming, I personally do think IPS panels are a much better experience.
Aside from that, I decided to splurge on the BenQ since I have a 1.5L hardware budget from the company I joined recently - so I just decided to blow it all on the monitors since the rest of the rig was something I was planning to set up anyway.
Post automatically merged:
theitdepot, primeabgb aren't responding to emails or even picking up calls
Is the supply situation that bad? Amazon prices are a lot higher and some items not even available.
