0-20k Need a rig for Programming and used for working in Unity ENGINE
@ALPHA17 :
1. NZXT Source Elite 210 OR NZXT Gamma ??? (NZXT Source Elite 210 is 2400rs, Nzxt Gamma is 2200rs)
2. Seagate 500gb SATA III 7200rpm or WD Caviar Blue 500 GB? (
Seagate 500gb 3800rs)
3. Corsair CX430 V2 or Seasonic S12II 520W ? (Corsair CX430 V2 is 2350rs)
4. Patriot 2GB DDR3 or Corsair Vengeance 4GB ? (Patriot 2GB DDR3 is 400rs , 4gb Vengence is 1650rs)
5. APC 600VA
or APC BR800VA-IN (APC 600VA is 2000rs)
* price from lamington road.
@jom jose here are your answers --
1) Go for the NZXT Gamma, much better airflow and cable routing options. You can add fans later to improve upon the same.
2) Go for the which ever hard-drive you fancy, both perform the same under real-world workloads. I think Western Digital has a longer warranty. Confirm before purchasing.
3) Go for the Seasonic S12II 520W as you plan to add a graphics card and a more powerful CPU down the line.
4) That was a limited one-day offer. Best would be sticking for 4GB x1 of Corsair ValueRAM ~1300/-.
5) APC BR800VA-IN because the 600VA variant will not be able to take the load of a 520W SMPS when it would be running a discrete graphics card.
And I know these prices are from Bombay, thanks very much.
One more doubt :
DH67 motherboard as per intel site it supports DIMM 1066 and 1333Mhz?
i didnt saw 1600MHz support?
Yes the motherboard's of the Sandy-Bridge family [Z68 / P67 / H67 / H61] all support RAM up-to only 1333MHz, even the integrated memory controller on the processor itself can theoretically only use a 1333MHz RAM module. But if you are willing to over-volt the memory a 1600MHz RAM module will give ~10% -->15% increment in bandwidth performance.
More on the same in these two articles --> AnandTech - Sandy Bridge Memory Scaling: Choosing the Best DDR3 / DDR3 SDRAM for Sandy Bridge: Choosing the Best Memory for LGA1155 Platform - X-bit labs.
