need advice for quest 2 battery duration
Ritvik shukla
Inactive
Beginner
So, I bought a quest 2 128gb from amazon and the battery duration is pretty bad. I tried to search for power banks for vr (Tiny ones like capsule), but only a 3000 mah micromini was available which gave 1/2 hours of extended battery. I need some suggestions on which powerbank I can use to extend the duration of quest 2 battery. I don't really care if it charges the internal battery of quest 2 I only want it to extend the usage duration.
I used to use a 10000 mAh Mi Pro power bank which fits in the pocket with my VR headset.
