plasma said:OP hereI just bumped up my budget to 33k(VAT included).
Just for argument's sake.. What about the Phenom II X3 720BE? Is it available in the market? If it is about 6k I could go for a cheaper Biostar DDR3 board and accommodate it in the budget(only just!).
No L3 cache = performance loss, and don't worry we were all "NOOBS" at a time so it doesn't matter when you decide to upgrade yourself to a new level in tech, just that you must be ready to take calculated risks and these days PCs come with enough safety net that even if a system should crash it is up and running in no time and with minimal hassles.funkysourav said:since plasma is a newcomer to the performance gaming scene
the correct word is "NOOB" ,
sorry plasma no offence meant!
it is not safe to recommend him or anyone new to the scene to unlock cores or overclock
he needs the best stock and stable computer he can get at that price..
besides there isn't any discernible performance difference between Phenom II X4 955(B55) and athlon II X3 435 at
resolutions on or less than 1600x900(even after using 5870)source toms hardware
besides if his unlocking doesn't work he will be stuck with a dual core 555BE(slower than athlonIIX3 435)
so better go for the economical athlonIIx3
and invest the difference on better gpu
The i5 530 is no match for the Phenom II 945 so the config you give is a bit lower on the performace front, also the 5670 is a HTPC card won't fare well on gaming frontRamPagE said:Intel i3 530 - 5300/-
Gigabyte H55 - 4350/-
Seagate 500gb - 1900/-
CM 310 - 1480/-
CM 400w - 1600/-
Kingston 2GB x 2 ddr3 - 4500/-
Ati hd5670 1gb gddr5 - 5850/-
Samsung B2030 - 6450/-
Hp dvdrw - 920/-
Bought this pc for a friend today from nehru place. Best config you can have.
As u are on a tight budget i would say may be skimp on RAM and go for Kingston ones or Corsair Values ones. Should be arnd ~4.6k-4.7 for 4GB.plasma said:Hi, Sorry for late reply.
After much thought and increase in funds I have gone for the below config, most of it as suggested by Dark Angel. Will buy it mostly on next weekend.
I got the below prices from Prime through phone.
AMD PhenomII X4 945(3GHz, 4 cores, 6MB L3 Cache) - 7000
MSI 785GM-E51 - 4100
RAM 4GB 1333MHz Corsair/G.Skill DDRIII RAM - 5350
HDD 500 GB Seagate 7200.12 - 1950
GPU Sapphire HD5770 1GB GDDR5 - 9300 [MSI HD5770 HAWK Not available at Prime]
Monitor Samsung B2030 - 6600
Cabinet CM Elite 310 - 1600
PSU/SMPS Gigabyte Superb 460w - 2100
L.G. SATA DVD-Writer - 950
Total - 38950
It exceeds my new budget of 37k, but still I would have expected to squeeze in a HAWK 5770 for this price. RAM price seems slightly steep to me. Please comment on the prices.
I saw on their site that they have the MSI HD5770 HAWK for Rs.9350! But when i called them they said they were out of stock!! I want to go for this card. Any idea where I can get this card if not at Prime in Mumbai?
AFAIK , the latency on USB is a bit lower than that of PS2 , wont make a BIIIG difference so a converter would do just fineplasma said:Does using some sort of USB to PS/2 converter for the mouse degrade its gaming performance?
Enjoy the new buildplasma said:Hi Guys!
Finally bought my PC and assembled it yesterday[It was fun!]. Runs like a dream so far! Already played Dirt 2 Demo and COD: MW2 as a test and was very happy playing at highest settings!!
Thanks to EVERYONE who posted on this thread. You all ROCK!!
Special thanks to DarkAngel, aman.pitbull and everyone who gave valuable advise and shared their knowledge with me.
Refer to my sig for the final config.
Only have one issue with the monitor(Samsung B2030), I cant make it upright... meaning I cant tilt it and make it face me straight... It faces downwards a little.. No issues for me right now. I'm happy with it but need to figure it out today.
| | AMD Phenom II X4 945 | | MSI 785GM-E51 | | Corsair XMS3 2 X 2 GB 1333Mhz | | Seagate 500 GB 7200.12 | | Sapphire HD5770 1 GB :hap2:| | Samsung B2030 Monitor| | Gigabyte Superb 460w| | CM Elite 335| | Sandisk Sansa Clip 2 GB Black | |![]()
DarkAngel said:Enjoy the new buildSO what are the final cost of the rig? Same as the one mentioned in previous post + 500 bucks extra for elite elite 335?
