tech.addict
Herald
archat68 said:What sensors are included in 25K? Please enlighten us.
Party Monger said:What do u do in case the thieves cut the power supply?
var89 said:battery backup is 3 days. cutting power supply will raise alarm.![]()
Gaurish said:that cost includes installation ? and can this kit be installed in existing homes without damage/modification to property?
Party Monger said:Is it in all the sensors?
What i meant was, if the wires are cut, then what?
var89 said:yes that includes the cost of installation. the system is completely wireless so only the main unit need wire for electricity.
any wire cut will raise alarm. come on ...companies will keep this in mind, in fact this is the first thing which comes to mind to override the system.
Gaurish said:Since its Wireless, it must be prone to Radio frequency (RF) interference. In my house whenever Microwave Oven is being used, it becomes next to impossible to browser via home's wifi network.
any wired option available?
blr_p said:Does it have some sort of self-test to check everything is working ok.
THing with a system like this is regular maintenance, how does that work out ?
