Hello All,
Looking to replace my current pc, current setup
Questions
some more info
- will prefer a setup which is quiet and runs cooler
- maybe because of above prefer intel based setup (but open for suggestion)
- DDR5 based , as i keep system for long time
- onboard graphics is must as backup
- need a low cost Graphic Card too, if needed.
- MB need to have good audio chip
- need cabinet too, nothing fancy simple and airy
Thanks for Reading
Questions
- What is your budget?
- No limit but less the better
- CPU - Intel i5 4440
- Motherboard – Gigabyte B85M-D3H
- GPU – Nvidia GT630
- RAM – 16GB gskill ddr3(4x4)
- Monitor – LG 27GL850
- PSU - Corsair GS500
- HDD – Crucial 500 GB sata SSD
- HDD – SATA WD black HDD
- Audio – Asus xonar dg pci card
- Logitech Mx Master 2S
- Microsoft Ergo Keyboard
- Monitor - LG 27GL850
- not sure what else i can keep
- Note sure ,Please Suggest
- Yes, maybe will add more ram if needed
- jaipur
- Open to online purchase
- No
- Linux as major OS,
- programming(python/php)
- music
- movies
- As my current configuration suggest i keep pc for long time, so need a trouble free system, current Gigabyte and Intel system really served me well
- No Gaming
- No Gaming
- No
- Linux - Mint/Kali/Ubuntu
some more info
Thanks for Reading
