titana said:^^Newegg would have been cheaper
BF1983 said:^^ Umm he mentioned 4200 !!! Anyways you made a good choice with the JVC. They are considered to be on par with the A900 which is far more expensive (cant verify that since I have neither, but when it comes from so many people on head-fi I believe it to be true.)
|Anish| said:I still have an option to sell them off. Not if i open them.. so you better tell me or else I will come to Baroda and snatch "MY" computer from you :lol:
Perfect answer, just what i needed to know!cyberjunkie said:Xonar DX drives the RX700 without any issues. The RX900 should be just about fine. If you feel they need some amp-ing, you can start off with a cheap Fiio Amp. There's a wild argument/discussion here - http://www.techenclave.com/audio-zone/discussion-about-the-fiio-amp-139671-2.html.
Use the Xonar DX + RX900 as a cheap starting point. Your setup will definitely be miles ahead of all the Rs. 1000 - 2000 locally available headphones running on onboard sound solutions. Give them a week or two to burn-in.
Once you know you like what you hear, you can go ahead and buy the Xonar Essence STX, a more expensive amp and headphone.
WingZero said:^^from wt i read rx 900 has larger cans giving somewhat better bass...otherwise both are same and both produce excellent bass as needed by u
