CPU/Mobo Need help deciding my rig!
Like I said before running a quad core cpu on a motherboard with NF7050/610i is not a very good idea but as Q6600 is a old 65nm cpu it should be supported by the board you have but still it deoends on the manufacturer.
Why I'm saying this ? - have a look at the links I've posted before in which an asrock motherboard supports every Q6600 cpus on the other hand the xfx 610i motherboard only supports 95W TDP Q6600 cpu.
BTW, FYI Q6600 has two versions one with B3 stepping [ 105W ] and another with G0 stepping [ 95W ] .. now most of the motherboards with 610i chipset supports the 95W TDP Q6600 cpu so see whether the Q6600 you are is a G0 stepping cpu or not first.
the one i'm getting is GO one!
