CPU/Mobo Need help deciding my rig!
check with your motherboard manufacturer website to see whether there's any further bios update released or not or better post the exact model and manufacturer name of the motherboard.
are you sure it's Zebronics not Zotac because I could not find any zebronics nvidia 7050/nforce 610i mobo on zebronic's website .. anyway, even if there's such a product I would not dare putting a quad core cpu on a such mobo simply because the build quality can't be trusted.
Agree, 610i is pretty old and it doesn't seem that it supports Quad core processor.
BIOS Version/Date American Megatrends Inc. 080015, 3/29/2008[DOUBLEPOST=1383476036][/DOUBLEPOST]
Zebronics NF-7050 mobo
BIOS Version/Date American Megatrends Inc. 080015, 3/29/2008[DOUBLEPOST=1383477214][/DOUBLEPOST]
so, after updating the bios.. would Q6600 support my mobo??
Specifications
Chapter 1
Introducing the Motherboard
• DDRII 667/533 SDRAM with 64 bit Single Channel (N73V)
• DDRII 800/667/533 SDRAM with 64 bit Single Channel (N73PV)
• Two DDRII DIMMs (240pin/1.8v) with maximun memory
capacity up to 4 GB
• 7.1 channel audio codec by Realtek ALC883
• 10/100 Mbps LAN by Realtek RTL8201N (N73V)
• 1000 Mbps LAN by Realtek RTL8211B (N73PV)
• MCP73V: GeForce 7050/nForce 610i (N73V)
• MCP73PV: GeForce 7100/nForce 6 0i (N73PV)
• LGA775 Socket for Intel Core 2 Quad/Core 2 Duo/Pentium Dual
Processor Core/Pentium D/Pentium 4/Celeron processors
Chipset
Memory
LAN
Audio
Expansion
Options
• 1 PCI Express x16 Graphics Interface
• 1 PCI Express x1 slot
• 2 PCI slots (v2.3 compliant)
• 1 IDE connector (supporting up to two IDE devices)
• 1 Floppy disk drive interface
• 4 SATA connectors (3.0Gb/s transfer rate)
FSB
• 533/800/1066 MHz (N73V)
• 533/800/1066/1333 MHz (N73PV)
Found this on my mobo drivers cd's manual.....
Like I said before running a quad core cpu on a motherboard with NF7050/610i is not a very good idea but as Q6600 is a old 65nm cpu it should be supported by the board you have but still it deoends on the manufacturer.
Why I'm saying this ? - have a look at the links I've posted before in which an asrock motherboard supports every Q6600 cpus on the other hand the xfx 610i motherboard only supports 95W TDP Q6600 cpu.
BTW, FYI Q6600 has two versions one with B3 stepping [ 105W ] and another with G0 stepping [ 95W ] .. now most of the motherboards with 610i chipset supports the 95W TDP Q6600 cpu so see whether the Q6600 you are is a G0 stepping cpu or not first.
Let me be clear... I'm looking forward to buy C2Q for short-term i.e., 4-6 months.. After that.. i'll upgrade whole rig, probably to amd fx6300.. But not now.. Now i'm in need of a quad core, 'cause of my mobo.. Which is a lga775 socket one.. I'm just curious which C2Q would be good and supports my system, which has a 450w psu as well..! My monitor resolution- 1440x900.. I ran max payne 3, Gta 4 at this res. With high settings!
Q9550 is best for the legacy C2Q. Doubt you will be able to find one.
