valar007
Level D
Hello. The apartment I live in has power backup but it is via Diesel generator. So if the power goes out, it takes a good 30 seconds to a minute for the generator to kick in. And once the generator comes on, the router takes 2 minutes to get connected to the internet. In this day of WFH, if one is presenting/demoing something, this is quite unacceptable.
My set up is very simple. There's one switch board that has 3 plug points. The 3 plug points are taken up by the TV (32-inch model), the cable set top box and the ISP's router-modem combo. A while back, I was looking at just purchasing a "router UPS" like this one. But the reviews aren't convincing and just for a little bit more money, I can get an entry level UPS and supply power while the generator is kicking in.
I looked at some brands like APC and MicroTek but not sure which brand to go with. The UPS is going to be used in a very hot and humid area (read near a coastline, Udupi, Karnataka).
Need help in choosing a UPS that can solve my issue and has 4 sockets, that can withstand the hot and humid weather and that lasts for at least 4 years. Thanks!
