Need help in deciding an air conditioner - 1 ton vs 1.5 ton
LG installation was free IIRC. We haven't had the need for LG ASS in last 3-4 years (touch wood).
For Daikin, the installation is sometimes free (during offers) and sometimes not free it seems. So please double-check if your chosen brand and model has free installation. I chose Daikin this time as it was recommended by someone I trust in these matters (I know nothing about ACs myself - LOL).
Here is a way to improve "coverage". Put the AC on the desired temperature and also put the ceiling fan on a low speed. This hack helps a lot with comfort in the corners especially.
All the best!
Just get Mitsubishi Heavy duty or O General (less preferred, but still good) and call it a day.
Never has my Mitsubishi AC disapppointed, makes us feel like we are in a hill station in like 5 minutes max, and then we stay their.
Even for 1.5 ton those are like 70k+ isn't it?
Go with a 1.5 ton because most manufacturers after covid are short changing because if you do look at the specs more carefully you will see it might only be 1.3 or 1.4 ton but marketed as 1.5 ton.
do the following calculation when buying. you will find the cooling capacity mentioned in the bee star label sticker.
12000 BTU = 1 TON
Cooling capacity*3.412 = BTU of ac
BTU of ac/12000 = actual tonnage
They are using such clever tactics now. Calls it 2 ton but has only 6100w cooling capacity. Now there is even another confusing thing, in cooling capacity they say min 5000w and max 5800w, instead of one value.
They even started not showing specs info in manuals.
Following is my experience with air conditioners your mileage may vary greatly depending on your region. This is my experience in Chennai
LG: Great service, but felt cooling was a little lacking compared to Panasonic.
Panasonic: Never done any service till now, installation was prompt. Also great feature package for a reasonable price bought 1.5 ton for around 35k in 2022 I guess
Midea: Cheap 1.5 ton 3 star from croma for 20k. Installation again no delay also did vacuum which did suprise me. I think future spares won't be an issue since midea is like an OEM for many other brands also.
Hitachi and daikin were bought way earlier but are still chugging on but stories from friends and family about their new models are not that good seems like they don't have much presence now.
Voltas was like the gold standard in non inverter but their inverter models haven't been a hit don't know if it's a quality issue or whether they don't market well enough.
Samsung heard good things about their windfree models rest not sure about their cooling capacity.
Mitsubishi and O General are great ac but be ready to pay a premium and if something breaks spares are questionable since they are not manufactured here I think? not sure
Panasonic model with 5.85 ISEER one of the highest: https://www.croma.com/panasonic-vu-...del-copper-condenser-cs-cu-vu18akyf-/p/304105
I am planning to buy this Samsung AC , Can someone provide details regarding reliability and after sales service.
Ai is a gimmick but their app which shows stats like energy usage and wifi connectivity/linking with alexa is useful.4 way swing is nice. Samsung website has card offers also will be easier to schedule installation and future service/warranty claims.
The Samsung one you shared on amazon is 45k you can get the Panasonic for atleast minimum 50k using card offers and even less using tata neu app.
The panasonic sold on croma costing 45k is 2023 model.
For the 55k one, I am accounting installation charges also into the budget. Let's see going to visit offline stores this weekend will try to get free installation.
Ratings haven't changed for the past 3 years so shouldn't be an issue:
That is 3 star I think. 5 star cost 60k.
not sure if you know about it, but just in general, if in summers, temps go really high at your place, a 5 star AC will essentially function as a 1 star AC, its only when temps are maintainable, that a 5 star AC shines in electricity consumption afaik
No offense man, but you seemed to not understand ISEER rating.
probably I guess, this was from my experience, we have a couple of ACs, same capacity, same base model, just different ratings, and both approximately consumed the same amount of electricity when there was a heat wave in my town
That is feature of convertible/inverter ACs. Running at a lower tonnage when required. Technically we should should be calculating using max power, but is that max sustainable power, we never know.
How did you calculate the units used, do you have a smart plug?
And star is not only thing to go by, you need to check the ISEER rating, cheap 5 star acs just barely pip the 5.00 rating making them equal to a 4 star ac which are generally 4.8ish. 5.2 and up is what you should consider if rating is important to you
I am confused whether I should go for 1 ton or 1.5 ton. My room is around 100sqft, but it is on the top floor and I rented this place and might shift elsewhere in a year. I want to know if running 1 ton and 1.5 ton would cost around the same, if I buy the convertible AC or is that just a marketing gimmick.
I have narrowed down to 2 ACs. Would probably pick LG if I only need 1 ton.
LG 1.5 Ton 5 Star US-Q19YNZE​
Panasonic 1.5 Ton 5 Star CS/CU-NU18AKY5WX​
- got samsung's 4 star , 1 ton air con since 2015. no issues so far.
one ton should be more than enough for the room of that size. if the price difference between 1.5 ton and 1ton is not much they go for 1.5ton
Have their split 1.5ton inverter bought from flipkart in 2019....works damn good still and without issue. Service was good. Neber had any issue. Have 2 godrej AC as well a window 1 ton fixed speed works flawlessly since 2019 and other inverter 1.5ton 3 star bought last year....that also works very good. No issue so far.
Than also bought Carrier window inverter 1.5ton AC last year.....service was good with 2 free services and works charmingly very well.....we use all our AC's at/above 26c and all cool very good without issue
Reactions: k_m_Arya
An update @Ssreek and @k_m_Arya, went to a bunch of offline stores. Croma was wildly overpriced, vijay sales had best deal for LG US-Q19RWZE 1.5 Ton 46.5k, felt like we can negotiate more. Panasonic is not being stocked in Vijay and Bajaj due to ASS Complaints, apparently. Let me try posting in Hyderabad Reddit to see if it is true
Reactions: Ssreek
Ya, surprisingly I visited Croma today. Their prices are a little higher.
Croma guys kept saying samsung and panasonic are good. The store I visited today, the salesmen weren't trained good enough.
