My config is as follows:
Background:
Day 1: The system was working fine with no issues. I just connected an extra internal WD 2TB hard drive (after disconnecting the power and data cable of one Seagate drive) to backup data. After backing up data, I shutdown the system and removed the hard drive and restored the original configuration. After I powered on the system, the system refused to POST and the hard drive LED stayed on from the time I pressed the power button on the cabinet. There was no display or beeps of any kind. I had to leave for work and so I let the system be for the time being, shut it down by pressing the power button and left. When I returned back later in the evening, I turned on the PC and voila! the PC turned on as usual. The hard drive LED blinked once (like it normally does during booting) and the PC turned on perfectly. I was able to browse the internet, played Quake III and watched an episode of HIMYM without any issues. The PC at no time displayed any erratic behavior. I later shut it down normally.
Day 2: My brother turned on the PC in the morning and it went back to the same issue- no POST. The hard drive LED was constantly on and the PC refused to POST. My brother turned the PC off and left. I returned back from work in the evening and turned on the PC. It booted as usual without any hiccups. I followed the same routine and then turned it off normally.
Day 3: I return from work in the evening and the PC refused to boot again. Same behavior- No POST and the hard drive light is constantly on. So, I turned the PC off to troubleshoot and get to the bottom of the issue.
Troubleshooting done so far:
Warranties:
Currently, I am completely stumped! The PC turns on but there are no beeps, no POST and no display. I am thinking something is wrong with one or some of the following components:
I don't have another power supply to test if the power supply is a problem. It will be really helpful if fellow users can provide some insight and suggestions for me to proceed to further troubleshoot this issue. Also, I don't have the receipt for the processor, In case, the processor is at fault (which I doubt), what would be the RMA procedure for that?
Please help.
Thanks,
4nd3r50n
PS: Sorry for the long post. I tried to be as elaborate as I could to provide a clear picture of what's going on.
- Processor: Intel Core i7 860
- Motherboard: Gigabyte GA-P55A-UD3R
- RAM: Corsair DDR3 Value RAM
- Hard drives: 2X1TB Seagate Barracuda| 1X300GB WD VelociRaptor| 1X90GB OCZ Vertex2 SSD| LG DVD-RW Optical Drive (All drives are SATA)
- Graphic Card: MSI GTX 580 (Backup- Sapphire ATi 4850, not connected in the system)
- Power Supply: Tagan StoneRock Series TG600-U37
- Cabinet: Lian Li Lancool K56
- Monitor: Samsung P2350 (connected via DVI)
Background:
- Removed power and data connections to all drives except the OS drive. No display, no POST, no beeps.
- Removed and re-inserted RAM. No display, no POST, no beeps.
- Removed display card and RAM. No beeps!
Warranties:
- In warranty- Motherboard and RAM
- Unsure: CPU- has a date of Nov-2009 printed on the Intel CPU box
- Out of warranty- Power supply
- Power supply.
- Processor.
- RAM
- Motherboard.
Please help.
Thanks,
4nd3r50n
