Ifb told motor conked out, and not sure if its really that. No i did not do anything of that sort.How can a motor just conk off. Did you try replacing brushes or is the winding shorted.
Check the second hand repair store for discarded front load washing machine motors. If the motor as the same mount option. Just swap the pulley to the same size. You may have a slight difference in rpm if the specs are different. In most cases a 10 year machine will have a universal brushed motor which can work on both AC and DC.
Most repair men these days are lazy. Those who take a effort to repair them will be unwilling to do so at customer premises. Since they have to search for spares from either company or from a salvaged machine.Ifb told motor conked out, and not sure if its really that. No i did not do anything of that sort.
First they told no spares available, then i explained to them that any appliances sold by them comes with 10yr part support.
Then they told me replacement motor will cost 5k. I a said fine. The next day they come back and say it will cost 7 to 10k,
No mechanic is interested in repairing old one. They simply refuse to come. They say ifb spares they wont get.
Thats the same motor brand and brush type in my 2008 whirpool.found this video -the machine is Gorenje , i found this when i googled for TYPE PS23/120 as seen in the pic in my first post. the machine looks same, including the stickers on the left side. Trying to get hold of a guy who can dismantle the motor and check the carbon brushes. fingers crossed.
I ordered the brushes from uk during covid and got them in 2 weeks by post and fixed them myself.
But since you don't even know whether its the really the motor problem Or if the motor contacts are bad or is the board working fine.
Why not remove the back cover and observe if the motor is spining/sparking check the brushes.
You have nothing to loose.
Can you share the link of the website from where you got the carbon brushes, just want to see how it looks.Carbon around the motor is common, the question is how much carbon brush is left. If its worn down all the way. The spring holding the carbon brush will uncompress and this cause the brushes to be loose in contact with the motor commutator which causes arcing and the heat generated due to this will delaminate the winding and the contacts.
Exactly same tactic was adopted by these IFB idiots when they came for the microwave. I told them to FO. I have decided not to buy any IFB since then.Then they told me replacement motor will cost 5k. I a said fine. The next day they come back and say it will cost 7 to 10k, and tell me to buy a new machine, they will give 20% discount on mrp.![]()
Got it. will check with a friend who makes carbon brushes for motors.
Just because this fit my motor doesn't mean it will fit yours. You need to see the orientation of the carbon brush which side has raised side and not to mention the physical appearance of yours vs this. Since some may have a raised side( the brush contact area) in left and some have it on the right.
10 yrs is kinda pushing it with any brand. Only 3rd party people will be able to repair it if they are interested.Exactly same tactic was adopted by these IFB idiots when they came for the microwave. I told them to FO. I have decided not to buy any IFB since then.
Do you work for IFB ? If yes, then you should stop touting this -10 yrs is kinda pushing it with any brand. Only 3rd party people will be able to repair it if they are interested.
I see the number 10. OP already said 10 yr old machine.Do you work for IFB ? If yes, then you should stop touting this -
Are you kidding me ? Both the 'demo' guys who came from my LG washing machine & Fridge were doing just that. Pushing unnecessary things.In any case, I have never found a "service engineer" just pushing for sales instead of doing what they are supposed to do, for any brand except this one.
I did not realize I needed to spell it out but then..Now what is your point ?
If you are confident enough to offer a 10 year warranty on a motor, how is that "pushing it". No, it is simply what I should get with my product. And definitely not for a technician to come and tell me first that spares are unavailable, as the OP said.10 yrs is kinda pushing it with any brand.
This and, in my case, it was not a product demo and its not about the racks, covers or stands which everyone tend to sell.Are you kidding me ? Both the 'demo' guys who came from my LG washing machine & Fridge were doing just that. Pushing unnecessary things.
