Hi guys,
please help i am deep truble with my win 7 64 bit version,
From last few days every time i install fresh win 7 64 bit, it start giving bsod error at startup after a day or two, it is happening even in safe mode. my xp and win 7 32bit are working fine.
i read about a torjan that cause sudh kind of error and ran ESETIRCBotANRCleaner but no sucess.
plz help what should i do!!
EDIT: Friends i got the cause of problem, its my RAM as soon i pull out the newely installed 2gb kingston stick out of 6gb windows boot fine,
now i am confused about the real fault because if i use same stick(only new one) and remove other two again system boots up ok.
i also tried using it at different slots and its ok.
so then again i put all three sticks together in the same manner as they were before and again system is booting up fine.
i cant find the problem is it the os that is not able to utilize six gb plz help if anybody has faced same problem before!!!
