Questions
- What is your budget?
- 60-70k (Considering no upgrade for 5 years minimum)
- CPU - i7-860 2.8Ghz (4 Core, 8 thread) (I've only used i7's since 2010. i7-920, 930, 860)
- Motherboard - Asus P7H55D -M Pro
- GPU - Nvidia GeForce GTX 1060 6GB
- RAM - G-Skill Ripjaws 1600Mhz 8GB
- Monitor - Dell 22inch + HP 24W
- PSU - Antec NE750G Modular Gold (1 year old)
- Cabinet: CoolerMaster HAF 912
- Cooler: CoolerMaster Hyper 212 Air Cooler
- SSD: Samsung EVO SSD for Windows
- Drive: WD Green SSD + WD green HDD for data
- Monitor for now.
- Keyboard Asus Tuff Gaming K3
- Mouse Logitech G402
I've picked some part names as per my budget idea from PCPriceTracker.in- CPU - AMD Ryzen 7 5700X Desktop Processor (8 Cores/16 Threads/3.4GHz) 100-100000926WOF
I'm thinking to try AMD for the first time since they are also cheaper these days. - Motherboard - MSI B550M PRO-VDH WIFI Motherboard (AMD Socket AM4/Ryzen 3rd Gen Series CPU/Max 128GB DDR4 4400MHz Memory)
I had a MSI x58 PRO-E in 2010 and my first impression was not so good. How's MSI these days? I'm fine with any other best-compatible brand/model too. - GPU - ASUS Dual GeForce RTX 3060 OC Edition 12GB Gaming Graphics Card DUAL-RTX3060-O12G
I will be running 2 displays - Monitor: Looking for suggestions for a 1080 or 2k budget-friendly monitor good with colors for gaming. 24inch minimum and 27inch maximum.
The above budget is not including a monitor. I am planning to use the current monitor for now and will upgrade by year end. - PSU -Antec NE750G Modular Gold (1-year-old)
Gonna use my current PSU. - Cabinet - Please suggest under 4-5k
- RAM: Team Group T-Force Delta RGB 32GB (2 x 16GB) DDR4 3600MHz Memory TF4D432G3600HC18JDC01
- Final for next 5 years minimum.
- Delhi
- Open to online purchase and sale prices.
- Gaming
- Browsing
- Office usage which involves 2 displays and 30-40 chrome tabs at once.
- Watching HD movies
- I prefer big brands like Asus, Gigabyte and others.
- Valorant
- Farcry
- Shooting fps games.
- Gaming - 1920x1080
- Desktop - 1920x1080
- No
- Windows
