metalspree said:Hi Sunny what happened to the jet engine did it stop ?? ,whats the status of your clothes ??
zhopudey said:Well, we can't tell if you did it right unless you post before and after pics of your clothes.
Eazy said:before....
after.....
Grease Monk said:dB? CFM?
I think the slots do matter. One for the detergent, one for bleach (if applicable) and one for fabric softener (again, only if desired). If you are worried about your clothes fading out over time, look around for versions of detergents that can use cold water. I use Tide Coldwater and then set the lowest temp setting on the machine. I guess the same applies to driers.
