bmwfanboy
Contributor
I need wifi capability in my desktop. I have Gigabyte GA78LMT-S2P with only 1 PCI slot and 1USB port left.
What should i buy?
1. a PCI based wifi card ? [this will be installed on my only PCI slot so i won't be able to use any other PCI cards in future, like USB card/TV tuner in case i decide to upgrade later]
2. USB wifi dongle [I have 4 USB slots at the back. and this will take one of them permanently causing a little inconvenience as i'll have to remove cables in case i want to use my gamepad/joystick.
3. should i buy a PCI based USB card and use its USB ports for USB dongle and keyboard/mouse? [This will add more USB ports which is a good thing, but i had previously bought enter USB card and it died in ~1year]
What should i buy?
