FS: Power Cooling and Modding NZXT and Xigmatek whited led 120mm Fans
can you put more info like Air pressure, RPM, CFM? or if you can put exact model numbers , i will search myself .
updated thread with model No. of fans also find below details for both Fans
NZXT - http://www.moddiy.com/products/NZXT-Rifle-12025-120mm-Brushless-DC-Fan-(1200RPM).html
Xigmatek - http://www.newegg.com/Product/Product.aspx?Item=N82E16835233015
NZXT
Dimensions: 120 * 120 * 25mm
Bearing: Rifle
Rated voltage: 12V
Rated Current: 0.16A
Speed??: 1200RPM ± 5%
Maximum air flow: 38CFM
Full noise: 16DB
Xigmatek
Dimension - 120(W) x 120(H) x 25(D) mm
Voltage Rating - 12 V
Starting Voltage - 6 V
Speed - 1500 R.P.M.
Bearing Type - FCB Fluid Circulative Bearing
Air Flow - 61 CFM
Air Pressure - 1.516 mmH2O
Life Expectance - 50,000 hrs
Noise Level - <20 dBA
