dasgupta_arup
That's what worries me treesize reported usage of 22gb tallies with what I get if I make all files including hidden and system file visible then select all and use properties.........but explorer says usage ~49gbIts strange that your leftmost picture shows ~ 22 gb in C drive of 50 Gb size, while the right ones show only 557 mb free space left, used space 49 Gb. Do you have hidden files that are not seen by treesize. In my case, the used space by treesize and windows explorer are the same.
Try compressing the drive, it will free up some space, may be 4-5 gb.
Can I do that without install of Linux??check the drive under Linux, it will show you each and every file and folder.
thanks for the info, tried it out
