CPU/Mobo Opteron 1xx vs Desktop parts [a inside look]
Anish
Forerunner
^^ Ahem Karan, Mhz isn't totally the king.
I completely agree that 3500+ will beat a 144 (which I mentioned if you read correctly ;))
As for 146 v/s 3500+, 146 has 1MB cache, runs cooler and consumes less power.
Also Opterons are made from Strained Silicon and tested more extensively. A 146 even at stock is a much better purchase than a 3500+ :)
Reactions: 1 person
When it comes to A64,CPU Clock Speed is the only thing that matters.the A64 is nt mem bandwidth starved as the P4 was.
Also the HTT bus cant be pumped to insane levels like the FSB in Netburst architecture.
So the bottomline is MHz [CPU Speed ofcourse] is the KING. ;)
@Darklord - if that is the case, then A64 3000+ venice and Opty 144 are the same right???? same 1.8Ghz with 512KB L2 cache... then isnt it better to get a A64 3000+ venice and then overclock it?? its better VFM right??
Well if venice goes higher then definately YES... Also as of now the Price difference between the two is a lot... Earlier a new Venice 3000+ costed 6500 while an Opty 144 7500 but as of now a Venice Costs 5500 and a new Opty costs 9500 :)
So For Price: Performance Ratio Venice> Opty
Venice's have 512KB Cache while Opty's have 1 MB Cache
:rofl: Switch...
Stop acting like a n00b. We all know that the 146 > 3500+..
As I cleary said before 144 > 3500+ > 146
End of debate ?
Anish said:
I quit...:cry: What's wrong ?
You wrote 144 > 3500+ > 146 .....
which implies 144 is better / greater than 3500+ , which is again better / greater than 146. (in performance at stock speeds i presume..) but which is contrary to what you have been saying from the begining of this thread.
">" = Greater Than
"<" = Less Than.
">" = Greater Than
"<" = Less Than.
Let it go Deejay... Thats the way we noobs do it... The leets do it other way round... Right Anish ;).................:bleh:...
Okey back to topic... i also know whats faster and whats not... A FX 60>Opty 146 so should he get a FX 60... I am talking Price:Performance here... An Opty at higher prices is not good if you are not sure about overclocking stuff :no:
Mods plz correct the price of the venice to 5500 in this post :)
guys pls tell me where the hell can i get my hands on opty 144 or 146 in india-better in kolkata.my dealer in kolkata is offering me an opty 248 for 10,000.
which is what i am confused -i.e; opty 144/146 or 248?
Dont go in for 248... Its a socket 940 and you will need ECC registered momory and a server class board.... Will update you on Opty 144 Availability :)...
Ohh yes deejay, I must have got confused :ashamed:
@ Switch - Even I was talking about price/performance, but let this thread go, its no use...
@ iamrahul - A 248 will only work on a 2-way board with 2 processors (so you need another 248 to get it running). Also switch has pointed out the other points
Hi Guys
What An Overhelming Response-the Reason I Love The Forum-u Guys Keep It Kicking
I Am From Bhowanipore Calcutta-anybody Nearby?
And Say Which Shop Is Selling The Beauties? Address/phone/contact Helps.
Hmm....
Opty 1xx series are "NOT" special in any form. They are just left over San Diego cores which AMD wanted to get rid off. So they branded it differently and sold it off. But, because of the "chance" higher OC ability of the initial batches, it generated a lot of demand and AMD had to specially continue manufacturing the "San Diego" cores which was against their plan. Hence they are trying to curb it with a price hike.
The A64 cores run cooler at the same speed compared to a Opteron because of less cache (translates less TDP.)
See the logic is:
A FX 60 with a TDP (Thermal Design Power) of 110 W consumes (and later emits as heat) 110W of power @ 100% load @ its stock Vcore. A opteron 170 (dual core), assuming its the best chip in the world, is also rated 110W TDP at its stock Vcore and speed.
i.e.,
FX 60 (@ stock Vcore, 1.35V and stock speed 2.6GHz) = 110W
Opteron (@ stock Vcore, 1.35V and stock speed 2Ghz) = 110W
Opteron 170 (@ stock Vcore, 1.35V and OCed speed 2.6Ghz) >>> 110W
Why? Because, AMD just doesnt speed bin the chips according to the max speed they get at stock volts (1.3, 1.35 and 1.4) but it also gives a huge weightage to the Thermal output of the chips. So if the chips dont cut the TDP design, they get thrown into different bins. Thats the point behind the whole "saga" of overclocking. We OCers land up with chips which would have actually come out as higher binned chips if it were not for the higher thermal output.
Eg: Take the case of the magical stepping of 0517 DPMW/EPAW....(Almost) All these chips would do 2.6 Ghz with default Vcore. It could be a bad batch of FX-57 Sandiegos which actually didnt meet the TDP requirement and thus were branded and sold off as different lower frequency chips. See it didnt cost AMD anything because a FX-57 wafer takes almost as much to manufacture as a 3000+ (its all dependent on the die size.) The first FX-57s were 0516 for the uninitiated (not sure abt this though.) That being said, there is also a possibility that many times AMD would have to take higher capability chips and brand them as lower parts just to fill the stocks and keep up with demand. Those are the really wonderful chips to get. Examples would be chips which do stock speed and even overclock at Lower Vcores (than default.)
Now coming back to topic:
Operton 144 = 1.8 Ghz 1MB L2 Cache
Opteron 146 = 2.0 Ghz 1MB L2 Cache
AMD 3500+ = 2.2 Ghz 512KB L2 Cache
You can urself check out that the TDP of all three processors is the same. So anish, your argument of 146 being a "better" silicon, cooler is totally unresearched.... so i argue for the sake of all, that please, dont post claims without any backing....
However, the 2xx and the 8xx are a different story. They are actually a different breed of processors (different socket, different memory controller, different number of HT lanes for enabling Dual/Quad CPU configurations.) and are unarguably more reliable and suitable for 24x7xyear operation environment. Hell, 285 are cooled by 1U hsf and they do just fine. (2 cores, 2.6 Ghz each, 2 MB L2 Cache)
Now you may ask why my sig reads Opteron 165 while i am so furiously defending A64, well thats because:
- I didnt know all this back then.
- Due to the amazing pri"z"e point she was being sold in. Switch rocks!
Regards,
Karan
PS: Dont mind this anish, okay.
Reactions: 2 people
blueyesdude said:
Guys,
3500+ is abt 10500.
opty 144 will be 9 max
Opty has 1 mb cache will be helpful for him in apps like maya where he will need it.
Even a bad yield opty,suppose even if he gets it will easily do 3500+ speeds.
Iamrahul check with ur dealer if u can just get the stepping code of the opty 144 from him and google it to know how good it is.
The extra cache is not something you will sacrifise 400 Mhz of CPU speed upon. However, if the guy is ready to buy some good cooling and overclocking hardware, then it may be worthwhile. Overclocking a 3500 will be easier, because the motherboard does not need to be able to go to high HTT speeds and be stable. A 11x multiplier helps a lot in that. Hell, even a ASROCK would be more than sufficient for overclocking a FX-60 under DICE or a chiller. The cold bug is so bad (its the clock generator not the memory controller that is coldbugged) that max HTT you can reach at < -10C is around 230Mhz. Rest of the overclocking is entirely done using the CPU multipliers and the memory upclock multipliers.
AFAIK, the 248 will need a socket 940 processor and registered ECC ram, but it will not need 2 processors to work.... it will do just fine with one of em plugged in. but no point in getting a 248 then is it? could hv done well with the 148 also (unless u craze very much to put in high priced and expensive ECC-reg RAM.)
imagine the situation if had to but 4 of 880 right away just because you wanted quad CPU provisions....:rofl:
so guys am i going in for opty or 3500? make up your minds , i am getting cofused-all of u r so knowledgebale that i cant read all of u at the same time:huh:
^^See it all depends on the price. First find out how much each of the processors costs in kolkata and also tell us if u are going to overclock or not. From there it will be much easier to help you. So find out the prices of Opty 144,146 and A64 3200+/3500+ and post it here.
I doubt if AMD will do that, as Opteron has the brand name of their server chips. They need those to be stable, hence they would be using better yield cores. Opty will yet have a higher success rate at ocing.
Actually i am with Karan on this... He is right abt the BIN part... Also a Chip is 99.999999% stable at Stock Clock speeds... Its the other components which makes it unstable...
Btw repped you Karan for some good info there :)
