mods..... i had started this thread with my post, and suddenly i come back, a brilliant idea "had" been implemented. ah well........
OT:
i told around 2 months back (again rough guess) that this thread:
http://www.techenclave.com/forums/opteron-939-oc-database-thread-64762.html
be renamed to a Opteron Overclock Discussion thread because by no stretch of imagination could be called a "Database" however it got no replies. but this was done uber quick. any reasons?
BACK TO TOPIC:
like i said, in the world of overclocking nothing is guarenteed. a guy buys 10 0550 UPMW chips and overclocks them to 2.9Ghz+, but he cannot give a guarentee that his next 0550 UPMW will do the same or anywhere near.
You cannot generalise which is better, if you choose 4400 over 0550UPMW DC opteron when you plan to overclock then you can be called a fool. We all know how 50th week DC opterons overclock. So it fianally boild down to the price and the stepping and user feedbacks. Which has better silicon depends on stepping and fab. Earlier opterons did had better silicons compared to later year 05 venice. 054x and 055x E6 venice were mostly trash.
hmm, yes buying a 4400+ over a 0550 UPMW would be retarded. but buying a select CDBHE over a 0550 UPMW would be a even better buy because then instead of being limited to 3.0-3.1Ghz you would be able to hits in the range og 3.4 Ghz-3.6Ghz because its common accepted fact that the "clock generators" in those chips are not cold bugged as badly as the BW/B2/B3/B1 etc.
Regarding "trash" silicon:
Do you realize that neither AMD nor INTEL produce chips so that they can be overclocked, rather their target is "probably":
1) get the stock speeds
2) minimum TDP (hence Vcore)
3) maximum "yeild"
they rate their produce depending on the type of yeild they get (meaning the number of working chips in a wafer) because at any point of time, a particular model is in high demand (which explains the sudden revival of production of 3000+) and thus they need to take higher bin to lower part workchains so that they are able to satisfy the market demand.
also: AMD has a process of self adjusting manufacturing. the manufacturing process keeps on adjusting to improve yeilds. thats why sometimes, the process becomes on "AMD"s viewpoint whereas the "OC"bility suffers badly on the overclockers viewpoint. A trend had been noticed on the new chips coming out now. they are doing wonderfully high speeds at very low Vcore increases in air but are getting badly coldbugged and HTT limited when going subzero. Some FX-60 are so badly coldbugged that when temparture are dropped below +14, it is becomign mighty dificult to take HTT any higher than 220Mhz. So it is quite possible that the manufacturing process is being adjusted to produce HIGH "air" clocking chips due to which the "sub" temp ocing is suffering. evidently, AMD is more concerned about producing chips which run stock @ 3Ghz+ on air instead of pertaining to a niche market of overclockers who can afford to free the core below 0C. I hope i hv not called "anyone" retarded in this
and made my point clear.
Dont get me wrong dude.The point i am trying to make is
Yes i agree AMD dumps bad cores [Meant for FX series] into lower models.I am just saying they will use it in CPU models that feature 1MB L2 cache and not 512Kb cache.Anyways this is all speculation,we REALLY dont know what is REALLY happening,do we ?
I Couldnt agree more with you. What I am rambling on about is, in the "wild", many weird chips are noticed:
1) Cores which are labelled 3000+ but are the size of a regular 2MB L2 dual core size.
2) Single core Venices, whose cores are actually those of Dual core manchesters.
3) Single core Sandys (no reference to hamara Sandy
), which are actually dual cores where one core didnt cut it.
Hence I was just pointing out a possiblity and GIVING a wild example of FX57 being dumped as 3000+. You cant prove me wrong, I cant prove myself right. Just a example to communicate my point accross. Hence I suggest not to bring that point up again.
Well Karan,SuperPi is not optimised for dual cores.Perfect way to compare would be to test 3000+ Vs 3700.
Comparing 3000+ [Single Core] Vs Opteron [Dual Core] is baseless,keeping into mind we are talking about SUperPi here.
You think i dont know that ?
I have myself experienced this,Superpi scores of my 3000+ are unbeatable by the Opty.
Dont tell me you were unaware of the SuperPi thingy.
For A64,MHZ is the king ------> Really? i didnt know that.Thats a revealation to me.
Hmm, lets jog you memory into the history. You said extra cache of "512KB" translates to a extra "200Mhz" gain. I was coutering that argument. When did I ever compare Single core vs dual core? You must be reading me wrong or something.
I said the 512KB cache does not straight translate to a 200Mhz speed bump. Infact it cannot do that. The cache helps in reducing the latency of the A64 core to the memory somewhat and thus its use it totally dependent on the application at hand.
What are you trying to say karan ? i dont get your point.
Also between these 2,just see the current rating,theres a difference of 10A.And believe me 10A is a lot of current,taking into consideration that we are talking about CPUs here.
You have a knack of missing my "point" dont you? Look at the TDP ratings. And Rofl man, you of all people, comparing currents? You do know that that 10A means "nadda" unless that exact voltage at which the current is being drawn is known? You tell me (test of you standard 10 studies):
20 A @ 5V
100A @ 1V
Which is more?
Crazy_Eddy said:
Agree again. I have no idea why everyone keeps claiming the Opty's should run cooler . Its only obvious that the more L2 cache you add, the warmer it is bound to run. In fact, the increased L2 cache on the Prescotts was one of the reasons why it runs so hot.
Thanks for the clearance bro. Exactly my point. Some more examples:
4400+ @ 2.2 Ghz with 1MBL2 x 2 has TDP of 110W whereas 4200+ @ 2.2Ghz with 512KBL2 x 2 has TDP of 87W. Go figure.
Darky said:
How ? this means AMD is giving one core free...lol
j/k
But i am not convinced that the 3500+ had such a huge demand and AMD had so many spare Machester cores as to castrate them and sell as 3500+
Infact AMD is finding it difficult to meet the demand for their Dual Core CPUs.If we consider your logic then this means AMD is having a lot of spare cores.Care to explain ?
I guess you should frequent XS as much as you frequent VR-Zone then
Yes its true, the CCBWE 3500+ are dual cores where the second core didnt cut it. Didnt perform at stock Vcore, hence the processor was shelved. Does it mean that if you havent seen something, it "must" not exist? Also, no one has found a way "still" to enable the second core in a full proff manner. They just are sure because of the stepping and the huge core size which is much larget than usual Venice cores.
and finally:
Once you ask to compare the 3 which includes 3500+ then you say you are not.Please,you may call me a retard,but i am confused here.COuld you please make your point more clearer ?
ROFL man. I indeed asked told him that AMD 146 is not superior silicon when compared to 144 and 3500+ because you have the 3500+ which clocks 200 Mhz lower and runs cooler compared to the 146. BUT, the 146 is superior when just put in context of a 144 and a 146. End of story? Itna parishan kyun he mamu?
So ?
Also i would love to learn more about this tool.Please help me.
Take
NIRVANA.
Our very own TE thread regarding that:
http://www.techenclave.com/forums/tcasemax-tdp-and-overclockability-60036.html
Google and TE rocks:
Nice to have this debate with you guys....
