P990i Wifi Adhoc Mode Transfers possible or not
Quad Master said:
Index of /dd-wrtv2/downloads
there are so many files to dld
also wats the adv of this firmware.
EDIT : Added Later
So these are like hacked firmwares which unlock hidden potential of the router.
It requires a lot of reading on that site to download the perfect file and use it.
Hey Raghu can u tell me what added advantages did u get from the dd-wrt firmware on ur G54S.
Oops i double posted by mistake.
Quad Master said:
Calling all P990i users.
Hi Guys
Is there a way to transfer files to the PC or Laptop having a WLan Card.
Is there a way to share internet using a Wlan card in Adhoc mode.
I tried to establish a connection using 2 P990i but none of the phones
detected each other.
How do u connect a phone and a Wlan card in Adhoc mode.
3)Or
Is it compulsary to have a Access Point to connect to the PC.
Also
How to share your computers internet on ur P990i
[what hardware is required for this , can i share using wlan card
in adhoc mode]
I have never used Wifi nor configured Wifi.
Which is the cheapest n best 802.11g Wifi Access Point.
It is possible . I have P990i and i am able to connect with my Frnd's lappy .
Here is Step by Step Guide.
1) Go to WLAN Menu
2) Turn On the WLAN
3) Click On WLAN (TOP) >>
4) Click on New Account > In Account Name just Put any Name
5) In Network Name (SSID) Put any Name
6) Authentication - Open
Now this is the Main Step Infrastructure Mode and Ad Hoc Mode
7) Choose Ad Hoc Mode
8) In Channel. Choose Any Channel from 1 to 11 . ( And Also Set the same Channel In you Lappy . Otherwise Your Lappy wont find P990i's SSID ) .
9) Now Click on Right Arrow (>) .
10) Data Encryption - None
And now Save the config . and Your done .
Find the SSID in your Lappy . and u will able to connect with Your P990i
Thanx
Reactions: 1 person
@cisco_tech - Thanks for ur step by step reply , will try that.
Can u please provide similar steps for connecting to a Access Point.
I have a dialer based net connection will i be able to share net on my P990i
using the buffalo access point.
Also is it possible to connect one P990i to another using Wifi.
Added Later
This is how my setup will look after getting a Wifi AP.
I wanna know how will i be able to share net on my P990i using the AP.
Now i havent done this yet . but will try with my friend's 990i .
mostly it should work .
do lemme if it works with ur friends p990i
as i tried out with my neighbours P990i and got frustrated as i wasnt able to connect.
