god's_gift
Contributor
friends my nv-gs35 minidv camcorder is not at all switching on
i tried the battery with full charge..no response
also same with ac adapter
then thought that may be prob with display..
if there is battery or direct power ..on opening the minidv lid it automatically pushes up the minidv even if the camera is switched off
now that is also not happening
i guess power is not being supplied to the inside board/sensor
and i used it even 10 days back
warranty is over... i hope i can get it serviced at non panasonic store as well
but i am apprehensive as one of my friend had bad luck of getting the sensor of digicam changed at such a shop
but will panasonic give service even after 1 yr?
and i am new to chennai so don't even know the panasonic service center here
should i go to ritchie street?...
any help from chennai people will be greatly appreciated.
