scott1391990
Okay, so today I upgraded my RAM from 16 GB (2x8Gb Corsair Vengeance LPX 3000MHz) to 32 GB (Adata Gammix XPG 4x8GB 3200 MHz) and my PC didn't boot.
Motherboard was showing yellow LED which meant there is some issue with the RAM sticks.
So I opened the case and rechecked if the sticks are placed properly or not and one stick felt little loose. Upon forcing it, it got stuck properly and the PC boot up fine.
I then closed the case and it again didn't boot. I removed the side intake fan cable and it boot up again.
Can someone help me identifying why after connecting the side intake fan, it doesn't boot up?
Initially I thought that it might be that the SMPS isn't able to provide adequate power but then again, the PC is just booting up, there is no way that the GPU is consuming 290W at boot so I ruled it out. Also, 2 more sticks of RAM would add a little less than 6W to the total power required so that also rules it out.
My PC config is
Ryzen 7 1700 at stock speeds with stock cooler
Asus ROG Strix B350-f mobo
32 GB RAM (4x8GB)
RTX 3070 TI (290 Watts at full load) [Recommended SMPS for this card is 750W but as I have a Gold rated 650 W SMPS I didn't upgrade it]
Corsair TX650M semi modular SMPS
3 intake fans and 1 exhaust fan
1 M.2 SSD and 1 SATA SSD, 3 x 3.5" HDDs
My PC config is
32 GB RAM (4x8GB)
