Pogoplug Pro - $29.95 - Approx. 2.75k shipped - Low power download box etc
spawnfreak said:
hey friends, I'm also gonna buy it in a day or two but can somebody clear some of my doubts since i'm a noob in such stuff.
How do we access its GUI? thru PC browser?
Will torrents work on it?
I dont have an HDD etc so can I simply plug in a 16GB pen drive to download?
How do we access its GUI? thru PC browser? YES
Will torrents work on it? YES. But not OOTB, you will need to install ArchLinux
I dont have an HDD etc so can I simply plug in a 16GB pen drive to download? YES
dinjo said:
Sorry for being noobish here whats the advantage of using SATA ? Unless its drastic speed difference
Speeds on a GbE network should be more over SATA instead of USB 2.0
After the insane ZTE Blade and Seagate Dockstar deal threads, here we go again! :P
Props to you varkey! :thumb:
How much better is what I looking for?
Yeah that Rasberry pi looks a hot product to grab when it comes out
signops said:
Enter Raspberry Pi for $25.
Waiting for it! The version with an Ethernet port comes to $35 though.
@dinjo : You can expect about 30-40 MB/s over SATA. But all this will matter only if you go for Gigbit Ethernet. Otherwise it doesn't really matter.
Sent from my Samsung Focus using Board Express
Even at 35USD it is a steal.
If not through ICC then how did u order this?
varkey said:
Received the Pro as well the Pink.
Actual shipping weight of two PROs - 2.55kg and one Pink - 1.55kg. So I hope no one ordered it through SnS! The volumetric weight was even higher.
Buy.com sent the Pogo Pink in a box with a volumetric weight of about 4kg. Thank god I didn't opt for ICC PPO or even SnS.
thanx! BTW is it easy to install ARCHLINUX coz i I dont want it to get bricked!
also, which one should be bought, pro? or pink? OR the old model b02 whatever its called
guys shall I buy POGO-B01 (pink colored) but i'm not able to understand if its the new or old model..
please can sm1 tell If it should be bought or not? I intend to use it as torrent downloading client.
and whats wid the wifi version? Only that it can download over wifi?
Yeah the only difference between Pink and Pro is that Pro has WiFi and internal SATA in addition.
