Storage Solutions portable hdd dropped from hand - not working .. need help. :(
alive hunter
Contributor
My 1TB Seagate Portable HDD jus sliped from my hand. And now its now working.
It seems the Mini usb port on the HDD has become loose.
Its not under Warrenty.
What can be done??? Help help.
Regards,
AH
Rip open the case... connect it to a PC internally and copy all your data ... then buy an external casing and use it if it passes any of the HDD fitness tests.
Thats why its always safe to use a pouch for delicate items like HDDs. First remove the casing and check if the HDD is working. then buy a portable HDD case and install it. But i havent heard about cases suitable for laptop HDDs...
spoke to the customer care.. its located near Saki Naka post office, andheri East.
will be giving them the HDD today afternoon...
hope for the best ..
will u all updated
yesterday,....
deposited my HDD to the ACCEL Care Centre, Saki naka opp post office.
the HDD had warrenty till 15 July 2015.. that was a surpricse to me..
they said they will check againt any physical damage .. and if approved .. they will replace the HDD.. but the entire data wil be gone ..
so hope for the best ...
Waiting for their reply.. 15-20 working days...
