Belkin is being pushed around because of their warranty and insurance coverage of upto 50,000 INR I guess.
Sorry for off topic but can I use this protector with Invertor port ? Purpose is to get more devices on backup and protect all of them ?
Devices would be router, hdd, pi, ps3 may be ?![]()
I used to do so with my now defunct, not inverter, but UPS.
Did that worked well ?
Potentially destructive surge might occur once every seven years. So what did a UPS do? It failed to provide any hardware protection on what was probably the only surge it saw.it did, for close to 4 or so years, until one surge took out the UPS.
I got a Belkin surge protector with phone line protection soley for Tivo purposes.
Yet my Tivo's modem still failed. And the '$20,000 connected devices warranty' did not help me. I jumped through many hoops, including finding the original recept for the surge protector (just under a year old) and I sent my surge protector to Belkin (paid for shipping), and was denied my warranty. They gave me a ton of crap, including that it was null and void b/c the Tivo was also connected to the coax line for cable (this was not mentioned as a thing in the warranty that can nullify it). Eventually it boiled down to a line in the warranty that said "Belkin at it's sole discretion can reject any claim for any reason".
Protection by a sacrificial device is a classic urban myth. It requires forgetting how electricity works.Well if in the case only the UPS got damaged due to the surge, we can actually use consider the UPS as a sacrificial device. Let the UPS get damaged to protect the other devices that are connected to it.
If a protector does not have that always required and dedicated wire to earth ground, then it does not even claim to protect from typically destructive transients. For example, Belkins have no such earth ground and will not even discuss it.
Largest hyped warranties are typically found in lesser products. Good luck getting those warranties honored. Warranties are full of exemptions. Newsman in "SONY TiVo SVR-2000" describes his experience:
If electricity is incoming to that UPS, then electricity is also outgoing into attached appliances - simultaneously. At the same time, that current is outgoing from that appliance to earth. Long later, something or some things in that path fail.
Protection from smaller surges is already inside appliances. Existing protection is why a surge can pass through a protector and attached appliance. Near zero protection in a protector is damaged. That same current is made irrelevant by protection inside appliances. So a 'sacrificial' myth is created to explain what is really robust protection already inside the appliance. In some cases, that protection is an appliance converting a surge current into rock stable, low DC voltages to safely power its semiconductors.
Do not confuse safety ground in a receptacle with earth ground. Those are electrically different.
Appliance need not have an obvious connection to earth. Some excellent conductors are some wall paints, vinyl floor tile, or even a computer wire hanging down behind a table to touch baseboard heat. Once a surge gets inside, it finds many conductive paths that we overlook. Some assume surges (ie lightning) are capricious. Because we learn what is conductive after the fact. Even a concrete floor is an excellent conductor. Best protection is to always connect that current to earth so that it need not find those so many other electrical conductors.
Sacrificial devices are an urban myth promoted when one forgets how electricity works.
after a thunderstorm the hdmi ports on my tv conked off even though i had unplugged it at the time to protect from surges. read a lot of posts on how the coax cable of the dth is known to be a big cause of this as the lightning strike may be conducted through it.
so it seems even if your surge protector helps you, you might still get affected by a lightning strike (unless you disconnect the coax cable on your stb)
A concept taught to first semester engineers is superposition. To a surge current, that that battery is a short circuit. Therefore a UPS battery gives a surge (ie on hot wire) more paths into an attached appliance on all three wires (hot, neutral, and safety ground).Now the power output coming out of a Online UPS is not the main supply power (to my knowledge, please correct me if i am wrong), it is the power from the battery. So in the case of a online UPS for a degree of surge the damage is limited to the rectifier and battery. A properly designed one should be able to create a short to earth (through a surge protection device) in case of a really high surge but this is sacrificial mostly.
Ha ha“Of course the moon's made of cheese - how else do you explain the holes and the yellow colour? The real question is, how can it not be cheese? It makes perfect sense.”
~ Albert Einstein ate the moon for his lunch - from uncyclopedia.
Anyway whatever I had posted is what I had experienced. Technically a lay person like me would not know about joules or impedance but I was thankful that Belkin protected my electronics system during a severe thunder storm. Most of my lighting and couple of fans and a refrigerator conked off during the storm. Since I had connected the HT and TV (including Bluray player, XBOX, media player) to Belkin, whatever happened the surge or the power did not reach the main switch instead the Belkin got hit and fried in the process. Also I was able to replace the surge protector as it was under warranty. I hope I have explained you enough. I had bought a similar looking one like this
http://www.amazon.in/Belkin-F9E800z...293459&sr=8-3&keywords=belkin+surge+protector
What kind of internet connection did you have, Adsl?Since this thread has come up again, any suggestions for routers? Our main router aka pfsense virtualized on ESXi took a hit on one of the LAN cards and we had a 6 hour downtime. This was complicated by the fact that due to the rains, getting spares took a hit as well.
Can you provide link for ethernet to optical converter?What kind of internet connection did you have, Adsl?
Few years ago, I had a surge through my cable broadband and it killed the ethernet port of my pfsense router. Now i use an ethernet to optical media converter between the modem and the router.
How does a surge enter on a cable that already has best protection? It doesn't.Few years ago, I had a surge through my cable broadband and it killed the ethernet port of my pfsense router. .
