Blade_Runner said:Actually tight regulation has no benfits for Cpu overclocking. See the table below, it shows the max fsb achieved for every psu. Test config included: Prescott P4 3.2GHz @ 3.8GHz, Radeon 9800 Pro video card @ 400MHz/365Mhz, 3 7200rpm hdds(40GB and two 200GB), a DVD-ROM drive, 108MBit wireless network card & two 120mm fans.
The difference between cheap/low-end antec 350 smart blue and the super regulated Antec Trucontrol 550w is less than 2mhz fsb which falls very well within the experimental/testing limit.
Edit: I am sure the senior members might have a few words/ personal observations to post about this phenomenon.
well actually Truecontrol is not that good at voltage regulation. It droops preety bad also, just not as bad as cheap brands. The real benefits are generally experienced when the regulation is achieved on the scales of 0.1V (i.e. a droop of < 0.1V from idle to FULL load.)
and here we are looking at the FSB frequencies. and we also dont know what exact droop was involved in each of the case. so very very hard to speculate anything from a simple image. i am sure if there was a PSU drooping by 0.4 V and one with droop of .05V, we would see a differnnce of 0.1-0.3V in the Vcore required to achieve the OVERCLOCK.
@ blade: i think you missed my point. I mean to say is that the tight regulation will allow the user to reach the same overclock at a lower Vcore.
