41-50k Price and quality check for i5 14400f build
The specification suggests that it supports 12-13th gen , does that mean i would have to update bios before using 14th gen cpu ?
And which one will be enough for cooling 14600kf
anything under the budget of 3500RS for now, will upgrade to AIO later.
Yes, need to update BIOS, might support USB flashing w/o CPU, read specs carefully.
Cooler - AG620 or CM 620S, you need twin fan twin tower cooler. Ignore antec as Deepcool & Cooler Master are much better brands.
Reactions: NikhilSingh25
It says Q-Flash plus , we r gonna get this one ,
Also getting the CM 620s
Thanks for your help. Really appreciate it .
