Mephistopheles
I am a prey to occasional BSoDs which annoy me to the core. I have been having this problem for long time, earlier it seemed to be a hardware issue as my error code suggested, I had asked for help earlier on but I couldn't comprehend the issue properly enough. On an average, I get a BSoD every 15 days or so, it could be more frequent then 15 days too. I have noticed from the past 2 months that most of the time it happens when Im playing a game (i.e. Warcraft TFT @garena). Im really pissed off , I got two BSoDs today while a multiplayer game was in-progress. Please help me out here.
My previous thread for reference : http://www.techenclave.com/pc-peripherals/need-your-wisdom-having-problems-my-137773.html
(The problems in the above link are no longer relevant, but the BSod problem remains but with different error codes)
Details from event viewer: (The two BSods that occured today)
Ist:
Log Name: System
Source: Microsoft-Windows-WER-SystemErrorReporting
Date: 04-01-2010 13:27:50
Event ID: 1001
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Shivam-PC
Description:
The computer has rebooted from a bugcheck. The bugcheck was: 0x0000007e (0xffffffffc0000005, 0xfffff880051a0ff0, 0xfffff88006151658, 0xfffff88006150eb0). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 010410-52775-01.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-WER-SystemErrorReporting" Guid="{ABCE23E7-DE45-4366-8631-84FA6C525952}" EventSourceName="BugCheck" />
<EventID Qualifiers="16384">1001</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2010-01-04T07:57:50.000000000Z" />
<EventRecordID>54504</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>System</Channel>
<Computer>Shivam-PC</Computer>
<Security />
</System>
<EventData>
<Data Name="param1">0x0000007e (0xffffffffc0000005, 0xfffff880051a0ff0, 0xfffff88006151658, 0xfffff88006150eb0)</Data>
<Data Name="param2">C:\Windows\MEMORY.DMP</Data>
<Data Name="param3">010410-52775-01</Data>
</EventData>
and the second:
Log Name: System
Date: 04-01-2010 14:05:18
Event ID: 1001
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Shivam-PC
Description:
The computer has rebooted from a bugcheck. The bugcheck was: 0x0000003b (0x00000000c0000005, 0xfffff8800516e4b3, 0xfffff88008a9cf80, 0x0000000000000000). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 010410-50700-01.
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2010-01-04T08:35:18.000000000Z" />
<EventRecordID>54616</EventRecordID>
<Correlation />
<Security />
</System>
<EventData>
<Data Name="param1">0x0000003b (0x00000000c0000005, 0xfffff8800516e4b3, 0xfffff88008a9cf80, 0x0000000000000000)</Data>
<Data Name="param3">010410-50700-01</Data>
</EventData>
</Event>
Another problem which i get once in 20 odd days is from warcraft. Its some memory reference error, I dont remember properly though.
I have taken memtest (2-3hrs) without any error and successfully passed windows memory diagnostic extended test.
My config is in my signature.
Ist:
Log Name: System
Event ID: 1001
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Shivam-PC
Description:
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Correlation />
<Security />
</System>
<EventData>
</EventData>
and the second:
Log Name: System
Event ID: 1001
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Shivam-PC
Description:
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Correlation />
<Security />
</System>
<EventData>
</EventData>
</Event>
